Liked 2 Times in 2 Posts
Where is a good place to buy light weight carpet ?
Liked 336 Times in 183 Posts
You want to buy Ozite super flex carpet comes in a variety of colors weighs almost nothing---stuff looks like those green scotch scrubbing pads weighs about 18 ounces per yard comes in 80 inch wide by how ever long you want---usually sells for around $18-20 per yard ---thats for 80 x 36 18-20 ----look at ---YOUR AUTO TRIM STORE check out their website---you will need about 3-4 yards depending on what size car you have and how much you are covering---fasten it down with aerosol trim adhesive to hold it in place---if you want to do a removable trans tunnel you can form it real easy and take it to an upholstery shop have them sew a real nice edge on it so it doesn't come unraveled ----FED 387
Liked 226 Times in 76 Posts
deleted
Andy Friar Last edited by Andy Friar; 08-07-2021 at 07:31 AM. Reason: dumb suggestion on my part |
Liked 55 Times in 29 Posts
Ez flex on ebay
Liked 20 Times in 9 Posts
Home Depot. Around $18 a roll, approx 6' x 8', very light weight, easy to work with. Used 3M Super 27 or Super 77 for aerosol glue.
Liked 20 Times in 15 Posts
long years ago...the rule book just said 'floor covering'. I showed up with burlap [gunny sack] material. all nicely glued down. he didnt like it, but did have to pass it.
Just an FYI. A lot of pieces in a purpose built car like the trans tunnel or side door stuff can be covered in a peel and stick material. It has a carpeting look to it like the inside of a glove box, it's light as a piece of paper and it holds up really well. If it gets damaged, peel it off and replace. I see it in a lot of Comp cars.
#8 | |
Liked 54 Times in 33 Posts
Liked 205 Times in 93 Posts
you just lay it right over & fit to frame rails etc?
