Old 07-24-2021, 11:51 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Converter flash
Jr, Can't really put a number to it. too many variables. small engine vs large engine,... where in the Tq curve the original stall was, ect. Each application varies. Change the gear, check it with your original converter and make changes as necessary. Like it has been said before... change one thing at a time and test. Your new gear may not like the stall the other set up liked. Don't forget about the low to second % gear drop may change. That may be where you need some help from a converter. Good luck Test, Test...
Adger Smith (Former SS)
