Old 07-24-2021, 10:35 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default Re: Converter flash
Originally Posted by Jeff Stout View Post
I went from a 4.30 to 4.88 and lost 300 on converter.
Thanks Jeff. What I was looking for on rear gear changes.
junior barns is offline   Reply With Quote
Old 07-24-2021, 11:51 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Jr, Can't really put a number to it. too many variables. small engine vs large engine,... where in the Tq curve the original stall was, ect. Each application varies. Change the gear, check it with your original converter and make changes as necessary. Like it has been said before... change one thing at a time and test. Your new gear may not like the stall the other set up liked. Don't forget about the low to second % gear drop may change. That may be where you need some help from a converter. Good luck Test, Test...
Adger Smith (Former SS)
Old 07-25-2021, 09:48 AM   #3
Jeff Stout
Liked 704 Times in 281 Posts
With gear change the data logger showed the finishline lock up went from 6.5 to 5.5. I liked that part but not the .05 loss on 60ft.
