Old 07-21-2021, 10:51 PM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Re: Stocker Horsepower
Originally Posted by HP HUNTER View Post
It would be a little over 600 but how the engine carries HP past peak is very important.
132 MPH @ 3400 = 602 STP HP
1320/132 = 10.00 Min
Hunter you have me curious on what you mean Carrie's HP past the peak.
littlemanjoe is offline   Reply With Quote
Old 07-22-2021, 12:12 AM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
The more the HP hangs on past peak HP RPM. The higher the RPM you can shift at and the more rear gear you can run. The opposite would be if HP nose dives after peak HP RPM.
Stan
Old 07-24-2021, 07:02 AM   #3
GTOMayhem
Liked 22 Times in 14 Posts
Stan
I have seen this mentioned a number of times and am curious about what factors contribute to an engine's ability to carry HP past peak.
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 07-26-2021, 03:40 PM   #4
littlemanjoe
Rick Thomason
GTOMayhem
This has me curious as well. So it's sounding like intead of worring about peak HP your focus in Stock is to have a long HP curve?
Old 07-26-2021, 08:15 PM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Quoting a good friend of mine from the left coast "Its the nature of the beast". Meaning, in this instance, that some engines, probably depending most on the cylinder heads, will be able to go quite a bit farther up the range past peak hp. than others can.
Jim Cimarolli is online now   Reply With Quote
Old 07-27-2021, 01:46 AM   #6
Stan Weiss
Stan Weiss's Avatar
Rick Thomason
GTOMayhem
Rick,
It will vary based on what someone is running. I have seen a cam change do it.
How many people when they dyno their engine make a pull more than a couple of hundred RPM past peak HP to really know what it does?
Stan
Old 08-01-2021, 01:25 PM   #7
HP HUNTER
Liked 373 Times in 129 Posts
Rick,
Stan
I think it would depend on the intended use of the engine, but more people than you might think run well past peak when dyno testing, they just don't show that data, just my opinion.
Old 08-04-2021, 09:46 PM   #8
Mike Mans
Liked 299 Times in 48 Posts
Rick,
Stan
I've echoed your statement for a long time as well. We run our engine on the dyno to the same RPM that we run on the track. If it crosses the finish line at 8000, why would you not want to dyno it to 8000 and understand how it is responding?
Mike Mans is offline   Reply With Quote
