06-20-2021, 04:16 PM | #1 |
Liked 679 Times in 269 Posts
Coolant recovery on 68 Cutlass
Current set up is 16 lb. cap with the overflow hose going onto ground. With 116 degree outside I'm running 235 and when shut off it will spit out a little. I'm wanting to run a recovery tank but trying find proper radiator cap to let water from tank suck back in. I believe my current cap is 1 way? I think. assuming tank needs hose coming from bottom to always be submerged into water and allow suction back into radiator when cooled.
06-28-2021, 07:44 PM | #2 |
Liked 232 Times in 73 Posts
Re: Coolant recovery on 68 Cutlass
Jeff, I'm not an expert but I see no one else has responded so I'll give it a shot. First, 235 degrees is pretty hot for an older car and sometimes I would find issues with timing or advance in the distributor especially on Buicks and Oldsmobiles that would effect the running temp. I'm pretty sure we bought recovery kits back in the day which consisted of a recovery tank, hoses, and I think a cap and they may have came from NAPA. The tank was pretty large, at least a quart maybe a little more
06-29-2021, 12:03 AM | #3 | |
07-20-2021, 11:13 AM | #4 |
Liked 59 Times in 9 Posts
16lb stant #10231 or 10230 radiator cap
Cheap rcovery tank https://www.autozone.com/heating-and...87_0?rrec=true Amazon |
07-20-2021, 08:03 PM | #5 | |
Liked 58 Times in 32 Posts
07-29-2021, 10:21 AM | #6 |
Liked 232 Times in 94 Posts
Go to Year One, and look at # S103,it ain't that much, and look like it should work.
07-29-2021, 11:48 AM | #7 |
Thanks everyone. I just sold car today. Heading to Netherland. I was surprised.
