Liked 101 Times in 27 Posts
Recently converted a livestock scale to a scale that will weigh one wheel at a time. If all wheels are exactly level including the scales, is there any reason I will not get an accurate weight adding all 4 corners ??? The scales are dead accurate and calibrated. Thanks for any opinions.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 227 Times in 138 Posts
I used to two of those scales and wooden block risers of the same height as the scales for the other two wheels. No problems with this set up. They belonged to Wayne Gapp! That’s what he used.
#3 | |
Probably more accurate than the scales at many racetracks! |
#4 | |
Liked 520 Times in 176 Posts
Respectfully, Henry Kunz 1534 H/SA |
