#11 |
Liked 49 Times in 15 Posts
The Racepak Sportsman appears to be the entry level unit. Their website states that out of the box it will record:
Engine RPM Drive Shaft RPM (Requires Driveshaft Collar Sold Separately) Accelerometer G-Meter Lateral G-Meter Battery Voltage 12 volt event Record Button What information would you gain from these inputs? Wheel slip, acceleration rate, missed shift RPM? What else would need to be added to that system when used on a carbureted stocker?
Dean Feiock -- Stock 5002 |
#12 |
Liked 80 Times in 19 Posts
So what data logger system is recommended? Additional what extra benefit does the MSD Grid offer?
#13 | |
Liked 734 Times in 385 Posts
You can see what is happening before, during and after a gear change. You can see what your torque convertor slippage is as the car goes down the strip. For similar weather conditions you can overlap Accelerometer / G-Meter data and see where in the run a change helped or hurt. Engine acceleration rate will vary not only for from one gear to another but also within each gear. One reason I like an inertia dyno fixed load variable acceleration rate engine test. Stan |
#14 |
Liked 99 Times in 60 Posts
to the above list, add fuel pressure, and you are well on your way to a consistent package
Larry Woodfin 471W |
#15 | |
Liked 706 Times in 283 Posts
#16 | |
Liked 974 Times in 310 Posts
#17 |
Liked 20 Times in 12 Posts
If you're going to buy Racepak, buy it from Greg Kelley at Motorsports Innovations.
If I could do it over, I would have went straight to the V300SD instead of the Sportsman. Don't get me wrong, I'm happy with the Sportsman, but by the time you add extra channels (and you probably will), the initial price difference between the two basically disappears. The support you'll get from Greg is top notch. The support I've gotten from Holley isn't worth the time I spent waiting on the phone to get it. |
#18 |
Liked 237 Times in 126 Posts
One thing I can add is that don't try to piece a data logging system system together on a budget as it just won't work well. Also keep in mind that you need a laptop (preferably with a second screen) and a secure place for a mobile data lab. An open trailer and a pickup truck won't really cut it.
#19 |
Liked 456 Times in 148 Posts
If your trying to go fast, yes they are a must have. If one is not, then the 2 K plus cost, by the time you get O2s, lap top etc, could be put to better use with a limited budget..
Steve Teeter Stk/SS 620 |
#20 | |
So use my combo as an example. I've had this car for over 20 years. Let's say I can run 1.00 under without to much effort. Lets say the new engine makes 20 HP more than the old one. Let's say the new transmission is worth a little more as well. So let's say that I believe I can go faster in the near future. Is a $1000 Sportsman system worth the money for the limited data gained? Is $1500 for the Sportsman system with single channel add on O2 sensor worth the money? Would a $1700 V300 system be a better choice? Or would I also need the add on single channel O2 sensor ( bringing that system to $2200)? And I think these options would still be considered "entry level". I could see a full system hitting $3000 to $4000. All opinions welcome...
