Liked 80 Times in 19 Posts
I have a 66 Chevy II with 283 Super Stock car. Are data loggers really worth the money for carburator applications? What value do they add? Best brands?
Thanks, Avery |
Liked 100 Times in 51 Posts
ABSOLUTELY.......
I've used Racepak since 2007. Everyone I know that has "finally" spent the money to get a data logger, wished they would've done it sooner............ Dan SC4698
Dan Foley SC 4698 |
Liked 886 Times in 238 Posts
The data you gain will eliminate guesswork and reliance on trackside " you spun the tires " observations .
Just having the basics of engine ,driveshaft and O2 will help save time and money by providing solid visual data graphs that can be overlaid to compare good and bad runs and make informed shock and suspension adjustments. Real world ,on the track O2 data is very helpful in finding the tuneup that not only can pick up ET for a heads up run ,but also find the perfect bracket mode tuneup that delivers consistency. Additional channels like oil and fuel pressure can also help catch problems before they result in destruction
Liked 708 Times in 285 Posts
Yes for sure. I have 1 on bracket/ small tire car with nitrous sometimes. I have gained 1/10 in 1/4 ET due to reading graph and seeing Converter was wrong by about 200 rpm and car was going to lean at finish line. I'm not the smartest guy but made me smarter and faster. Also I watched how oil pressure was fluctuating alot going down track. Adding 1/2 a quart of oil straightened out pressure reading and maybe saved a engine from being hurt.
Liked 26 Times in 11 Posts
Friend of ours had similar thoughts to yours, first time out with his Racepak system he had an oil pressure issue, discovered a broken oil pump pickup and saved an expensive engine.
He no longer wonders the value of data acquisition, See you at the races, Wayne Kerr |
Liked 93 Times in 52 Posts
Yes- and look into RPM Performance. Simpler, reliable and a higher level of personal support than Racepak.
Clark |
Liked 99 Times in 60 Posts
I agree with the yes answers. Having the basic data allow tuning a car to be very consistent. I like the Racepac system.
Larry Woodfin 471W |
Liked 2,513 Times in 701 Posts
My son Jon and I have similar 340 Stock Demon.
He dyno's his engines and has a Data Logger with a lot of channels. I do not use either one of those and mostly scratch the seat of my pants. Last week at Sac we ran side by side at the same exact weight and the finish was '.003 in my favor. Of course = He reminds me I was racing over 30 years in these cars when he was born.!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 06-17-2021 at 08:49 PM. |
Liked 928 Times in 263 Posts
Buddy of mine got talked into a pretty basic Racepac a few years ago. Has owned and raced the same car for many decades and thought he knew every thing about it (and his driving).
Put it in, took it to the track and made a few test hits. Looked at the data and couldn't believe what he didn't know. Made some changes and the car is deadly now. I'm a believer. Add video and you're set. Last edited by CMcAllister; 06-16-2021 at 11:10 PM. |
Liked 10,943 Times in 2,259 Posts
The first thing I learned with my data recorder is that I didn’t drive the car very consistent.
