Liked 323 Times in 63 Posts
Rory,
Do you have the MSD mechanical advance distributor ?
Bob Shaw V/SA 515 |
Liked 9 Times in 6 Posts
Hi Bob
Yes it is 85551 pro billet mech adv. So it is locked in and then nearest I can tell the dfi throws 20-32 (being 50 -64) at it until the car fires up, then it goes to 32 Thanks |
You need to take some of the timing out of the Start Up Term part of the Accel
You could most likely set it to zero and it will still start fine, you will have to try different settings and see what your motor likes |
