Old 02-05-2021, 12:53 AM   #21
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Default Re: I'm going to build a smooth idle 427 and drag test it
Took something I had made a few changes and did a rough simulation.
DA = 0
60 Foot ET = 1.5076
330 Foot ET = 4.4113
1/8 Mile ET = 6.9378
1/8 Mile MPH = 96.7141
1000 Foot ET = 9.1421
1/4 Mile ET = 11.0173
1/4 Mile MPH = 120.2224
Stan
Old 02-05-2021, 08:04 AM   #22
Frank Castros
My guess is 500hp based on the very high quality of the build.
Old 02-05-2021, 10:58 AM   #23
HP HUNTER
Liked 372 Times in 129 Posts
The first test is some what typical, and the second test was my best. From what I can see from the average power, that should get me there, 4200-6100 RPM (11.00) should be easy.
ID:	56752   Click image for larger version
Old 02-05-2021, 01:05 PM   #24
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
very nice!!
Old 02-06-2021, 12:28 PM   #25
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
HP... I'm just wondering if you made any pulls starting at a lower RPM ? It would be interesting to see what the TORQUE numbers would be from say 2500-3500rpm. Very Good results from this project. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-06-2021, 07:42 PM   #26
HP HUNTER
Thanks, I didn't pull it lower than 3500, I knew I'd never see that on the track, I doubt there was more TQ below 3500. I can tell you from driving the car off idle TQ is very good, but as you know theres always a trade off-and I'm sure it going to be on the top. But it sure runs good, just wonder what it could have made if I really got after it, intake work, oil pan work, lightened the bottom end up, 1.8 intake rocker, more compression. Vacuum was 15 inches @ 750 RPM @ 6400 feet altitude. Heres a video.
Old 02-07-2021, 10:16 AM   #27
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
There is more torque at lower rpm. Look where the tq is at 3500 rpm. Your correct and probably never see it at the track.
Old 02-07-2021, 03:23 PM   #28
Painter
Liked 162 Times in 45 Posts
Who did the carbs?
Painter is offline   Reply With Quote
Old 02-07-2021, 08:23 PM   #29
HP HUNTER
1. Harold Bettes Dissident
2. Vintage Muscle Car
Old 02-07-2021, 09:21 PM   #30
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
whats the weight on the car w/driver?
