Liked 13 Times in 11 Posts
How much can they vary within the same set without some negative effect on power? 2 inches , 4???
Liked 880 Times in 311 Posts
http://speedtalk.com/forum/viewtopic...42375&start=15
http://www.exhausting101.com/?p=37 http://www.speedtalk.com/forum/viewtopic.php?t=41836 Check these out & look into Calvin Elston. He blows away some myths about Exhaust systems.
Adger Smith (Former SS) |
Liked 1,880 Times in 422 Posts
Larry Meaux, the guy who does PipeMax software, is another good source.
Alan Roehrich 212A G/S |
Thanks guys...Adger , lots of intense reading there...LOL
Alan I have a copy of PipeMax also...I'll take another look. When he gives you a "range" of lengths that fit the harmonic order , then I can only assume that as long as you're in that range , even if there's length variation....you're good to fly. |
Liked 26 Times in 11 Posts
Some guys even run unequal length on purpose.....
See you at the races, Wayne Kerr |
Joe,
You are correct about the reading... & I am like you on the range of pipe length. I would say hit in there some where in his range. That is exactly how I had my headers built for my V-6 in a Gen 3. Even the steps vary some. They seem to work well. After all the header is just Rocking the TQ Curve up or down... 2 " on a 32" pipe is about 6%.. off the top of my head..
Adger Smith (Former SS) Last edited by Adger Smith; 01-29-2021 at 07:47 PM. Reason: add% |
#7 | |
In summary , he suggest more emphasis on the collector ( make that a merge) as a way of influencing the relationship between a primary too short or too large and its connection to recovering torque (in the event of too large a primary )...or , a smaller collector. |
Liked 165 Times in 59 Posts
i have built a few sets of headers for street cars,stockers and chassis cars ,, in a stocker engine bay is very challenging to map out your equal lengths, but being careful not to create restrictions by trying achieve equal lengths ,i always try to plot out the smoothest paths with out to many bends and using bigger radius bends where i can , collector sizes are like camshaft choices, you can get close but to find that perfect combo dyno testing is key to getting the most out of the combo, but as you know there just isn't enough time to test everything
in my opinion you want to focus on what you can build for torque ,,most carbureted stocker engines are done making power between 6200-6700 ,, torque around 4500 -5000,,, gmonde |
