Old 12-22-2020, 10:57 PM   #1
JoeCool108
Liked 3 Times in 2 Posts
Default Possible new Class build - need opinions
I have the chance to buy a 1989 Camaro 5.0L TBI with an auto. Looks like Its a natural O/SA car. Its a street car with no title and missing some interior parts, but I can buy it cheap.. Can this combo be competitive?
JoeCool108 is offline   Reply With Quote
Old 12-23-2020, 08:04 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Default Re: Possible new Class build - need opinions
The cam and heads aren't the best. Better combo is the 1990 5.0 TPI rated at 241.Better heads and camshaft and intake manifold.
Old 12-23-2020, 08:20 AM   #3
Billy Nees
I almost built one of these. It's so bad on paper that it's the kind of thing that I would do. Small cam (which doesn't seem to matter, lots of small cam 305s going fast),weird intake runner and not-so-good intake manifold. It makes tons of torque in a street car. I think that Tom Reese ran this combo for a while but switched to PFI combo.
Billy Nees 1188 STK, SS
Old 12-23-2020, 09:18 AM   #4
JoeCool108
I wonder if the 6 cylinder would be better, or maybe even an earlier year with a carb instead of the TBI? PFI might be better, but harder to find this cheap..Guy only wants 600 bucks for a complete car.
Old 12-23-2020, 09:26 AM   #5
Billy Nees
I guess that this would all depend on what you're comfortable dealing with. There's plenty of info available on any of the V8s so are you more comfortable with a carb or FI? With the 4 or 6 cyl., you're going to be pretty much on your own.
For $600, I'd be buying the car anyway. Check the lower cowl and the rear frame and wheelwells for rust.
Old 12-23-2020, 11:07 AM   #6
JakeB23
Liked 17 Times in 3 Posts
I’m attempting to complete a 6 cylinder project, but I’m concerned that I can’t get enough HP out of the cubic inches available. Basically I don’t know that I can get to 1.3 hp/cubic inch to mathematically get to the index. I would think it would be much easier to run a 302 V8 which is factored the same as my V6. They already have 30% more cubic inches, no mind the additional torque.. Either way I guess I’ll still be able to bracket race it on Saturday night..
JakeB23 is offline   Reply With Quote
Old 12-23-2020, 01:23 PM   #7
. It makes tons of torque in a street car..
That thing will move a full sized Caprice with no problem.
I'm sure it will run under in P/SA.
You have to maximize torque and then set the car up for it. (Small tri-y headers, etc.)
You might want to invest in a dyno test so you can figure out the converter and gearing...unless you're really good at this ;-)
Go for it...
Old 12-23-2020, 11:43 PM   #8
JoeCool108
So question, if its a natural O/SA car and you say it should run under in P.. is it safe to assume it will also run under in its natural class and its "Light" class?
Old 12-24-2020, 12:17 AM   #9
Just do the math... 13.15 vs 13.45
O to P , a full pound break, thus 210 pounds for three tenths.
Old 03-28-2021, 08:12 PM   #10
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Yes I would reach out to Tom Reese, because he is Very Familiar with the TBI.
If you need his phone number just let me know.
"Pistol" Pete Dutko
