Old 12-12-2020, 07:36 PM   #1
383bigblock
Default Stock 1975 Dodge Coronet. Mopar guys.
What engine in a 1975 Coronet 2 door would make for a good(consistent/competitive) combination in NHRA stock? 318 or 400? Can anybody recall seeing a 1975 Coronet being raced in Stock? Any ideas or information would be appreciated. Thank you.
383bigblock is offline   Reply With Quote
Old 12-12-2020, 10:51 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Stock 1975 Dodge Coronet. Mopar guys.
You might be able to outfit a 2 door as a Road Runner also.
Register and log in to research the options here:.
http://www.classracerinfo.com/
LOCOMOTION Racing
Old 12-13-2020, 12:00 AM   #3
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: Stock 1975 Dodge Coronet. Mopar guys.
Convert to 78 = just some trim change Grille etc.
318/230
360/276
These are the best factors for this body
We race both these combos with success
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 12-13-2020, 07:25 PM   #4
383bigblock
Interesting. Just for my own understanding why wouldn't the 190hp or 235 hp 400 engines be good as a combination? Is it because they, if I'm reading the NHRA classification correctly, have been factored to 310hp and 320hp respectively. Is the low compression that much of a hindrance? What about the 1975 360 190hp? Good combination even if its been factored to 276hp?
Old 12-13-2020, 09:21 PM   #5
GTX JOHN
The 400 in our 74 Ply. Sat. is 294 iron 296 Aluminum = same engine at 310 or 320 - You would not stand a chance against us.
The 360 / 190 if a four barrel would be OK.
The 318 to be a four barrel has to be 78 up.
John Irving
741 Stock
741 Super Stock
Old 12-13-2020, 10:35 PM   #6
383bigblock
Thank you for taking time to answer my questions GTX John. It is appreciated since I am trying to learn and you have the knowledge gained from hard work and experience. If you have the time could you explain why the 400 combination works in a 1974 Plymouth but may not be so good in a 1975 Dodge. Trying to learn the ins and outs. Thank you.
Old 12-14-2020, 01:15 AM   #7
GTX JOHN
Different Horsepower factors for similar engines in different year
cars.
My 73 400/Aluminum head = 296
Your 75 400/alum. head = 320
I/SA 12 LBs. per HP
Means your similar engine would have to weigh 290 Lbs
more than my car in the same class - An almost impossible
difference in weight to overcome give everything else is the same!
Much easier to change year of car when it is just grille/taillights
would give you a better factor or combo to work with!
The 78 318/230 is a great combo= we held the National Record and
many class wins including Indy before my son got bored with it and
decide to go faster!
The 78 360 started out at 270 and was a class winner and fast.
Eventually the Wagon was factored to 289 while the sedan was 270
making class impossible for us. Now all the 78 360 are at 289 with
either big cam or our old small cam version. The big cam is still
OK but no longer a killer combo.
Half the battle in Stock and Superstock is selecting the most competitive combo
out of some many possible choices.
John Irving
741 Stock
741 Super Stock
Old 12-14-2020, 08:24 AM   #8
Billy Nees
Liked 7,782 Times in 1,743 Posts
Originally Posted by GTX JOHN View Post
Half the battle in Stock and Superstock is selecting the most competitive combo out of some many possible choices.
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^This!^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^^^^
Billy Nees 1188 STK, SS
Old 12-14-2020, 08:28 AM   #9
Dave Gantz
Liked 251 Times in 125 Posts
It doesn't make sense, so don't be confused. NHRA doesn't make sense. There is not much logic.
Old 12-15-2020, 12:23 PM   #10
383bigblock
Thank you everybody for the replies and insight. As this would be my first experience with NHRA stock along with a couple of friends and we have a 1975 Coronet with a 400 it seems that if we went this route it would be a learning experience and wouldn't be competitive on a national level and/or in a heads up situation, not that we're expecting that. Might it be at least a consistent combination with either the 400 or 360?
