#1 | |
Liked 125 Times in 59 Posts
Do you monitor oil temperature? Use an oil heater? If you don't know what temp you are racing at it's hard to center on whether the oil is what is could be causing an ET difference. |
Just Trans temp but plan on monitoring both atf and oil temp next year.
Liked 348 Times in 79 Posts
Liked 1,583 Times in 582 Posts
#6 | |
Liked 805 Times in 245 Posts
Interesting sidenote, occasionally on the dyno, you accidentally get the oil too hot prior to a pull, counterintuitively the best thing you can do is fire the motor and it instantly sucks the heat out of the oil, it will drop 20 degrees if not more. Bringing up oil temp with the heater while the motor is turned off is easy, very hard to increase oil temp while the motor is running. Monitoring oil temp on a dyno definitely proves that cold oil sucks a lot of HP. |
#7 | |
Right on the money on an engine loosing power with cold oil. How many times have you removed the oil cap or valve covers and seen the accumulation of moisture before you make your first run of the day? I believe the best approach and practice would be to heat up the oil or run the engine until you go above 230 degrees F to get rid of the water vapor and burn the deposits prior to the first run of the day. A heater would be the best way and economical since you would not be running the engine and wasting race fuel. |
![]() SSDiv6 gave a good answer. In my experience it is really hard to get/keep that much heat in mine unless I am making laps within 20 minutes. The double races I hit and making late rounds of both I will see 250°. I am on alcohol though. I try my best to never hit the water with less than 150° oil temp though. |
Does this differ with steel vs aluminum pans?
