Liked 99 Times in 60 Posts
I have looked at the elements that bolt in a core plug hole but I do not like the fit. What other options are available?
I "think" I want a heater that will install inline the lower hose.
Larry Woodfin 471W |
#2 | |
Liked 1,604 Times in 583 Posts
https://rehermorrison.com/tech-talk-25/ Last edited by SSDiv6; 11-25-2020 at 07:26 PM. |
I have looked at those. Do you have a brand and size, and wattage suggestion? How long does it take to achieve 130 degrees or so?
Liked 230 Times in 94 Posts
I bought one from NAPA around 16yrs. ago that goes in the lower hose of my '67 FireBird. I think it is made by Everhot. I cover the front of the radiator with a big towel to help keep the heat in. It takes a while to heat up the engine as I have a big BeeCool Radiator. I'll go look tomorrow for the wattage.
Liked 333 Times in 180 Posts
Larry-- check your PM --Dick
Liked 129 Times in 59 Posts
These are the folks who make the "Zerostart" heater systems, both tank and silicone-pad style (like the Moroso unit). Hopefully some helpful information for you on wattage and capabilities.
https://phillipsandtemro.com/
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 240 Times in 112 Posts
I've got 3 of the magnetic heaters usually for winter use that I usually use. (Theres always people driving all over the pits "warming up", it made me think that's a lot of expensive gas not accomplishing much. I've also been told that I squeak when I walk
Dave Noll, EF/S ,?/SA 6526 |
I could not get to the front of the car as the snowblower and other stuff is in the way.Both NAPA and Tractor Supply have engine and oil pan heaters made by Katz and work great..The engine heater from T.S. is directional, does a good job for old style '99 Suburban.
Liked 28 Times in 15 Posts
I had the Moroso stick on on the bottom of the oil pan. Worked well for 10 years - finally quit. Check Google for pan heaters - us Northerners use several types that are available. Also had a freeze plug heater that was optional on my daily driver Jeep. Never had a problem.
Liked 174 Times in 39 Posts
I have these Zerostart/Wolverine heaters on the oil pan and transmission pan, can warm things up pretty quickly. Pretty sure this is the size I have on the oil pan, but the transmission one may be slightly larger. The offer a ton of shapes/sizes
https://www.amazon.com/Zerostart-340...6402804&sr=8-1
3207 D/SA, C/ED |
