Liked 334 Times in 181 Posts
Not sure if you wrote "its solved" but you can run the engine up to about 2500RPM and put a gloved hand or towel over the carb top when the engine has almost died remove your hand or the towel and let the RPM come back up---do this 2-3 times and see if it clears up ---what you are doing is going from vacuum to siphoning and jostling any particles that may been the bleeds or the idle passages--kinda self cleaning or sloshing process by going back and forth
