Old 09-10-2020, 09:10 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: 1970 Dodge 383 overbore
Kirk,
For basically stock engines my rule of thumb is to go by the piston sizes that are readily available. If they make a 60 over piston it should be safe to go that size. If you want to go larger with custom pistons you need to sonic check the block and then make a decision.
Bill Koustenis
BillK is offline   Reply With Quote
