Old 08-19-2020, 08:13 PM   #1
e vassar
Liked 271 Times in 107 Posts
Default Anti- sieze on NGK TR55 plugs
Yes or No?
Old 08-19-2020, 08:26 PM   #2
bykr
Liked 167 Times in 81 Posts
Default Re: Anti- sieze on NGK TR55 plugs
I always used anti seize with non taper seat plugs. They make a crayon like anti seize that I used to put a couple of swipes on the threads, when installing on aluminum heads.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 08-19-2020, 08:53 PM   #3
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Alum heads yes, otherwise optional IMHO
Tim H is online now   Reply With Quote
Old 08-19-2020, 09:18 PM   #4
e vassar
Chevy LS so yes alum heads. I did not install the plugs that were in this car, so I don't know if anti seize was used,or if they were over torqued. I had to use a 1/2 breakover to pop them loose.and I dont want to go through that again.
Old 08-19-2020, 10:04 PM   #5
Tim H
Tim H's Avatar
You must suspect that anti-seize was not used when you posted. I do not have the experience that you do, however I was taught that dissimilar metals should use anti-seize. 1/2 breaker , wow my father always told me not to go crazy, "they are only plugs not head bolts" LOL.
Old 08-19-2020, 10:14 PM   #6
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Yes, in aluminum.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 08-19-2020, 10:23 PM   #7
CMcAllister
Liked 920 Times in 259 Posts
Sparingly, just like the elbow grease used to tighten them.
Old 08-19-2020, 10:52 PM   #8
e vassar
Yes...factory spec is like 14 lbs ft
Old 08-20-2020, 10:45 AM   #9
curtis reed
Liked 125 Times in 59 Posts
I use this in aluminum heads.
curtis reed is offline   Reply With Quote
Old 08-20-2020, 11:45 AM   #10
Jeff Stout
Liked 706 Times in 283 Posts
I understand the anti seize because of 2 different metals, but I thought that it enhanced poor grounding of plug to head. Maybe I dreamed it.
