Old 08-18-2020, 03:49 PM   #1
racer913
Default MSD Pro billet distributor replacement for SBC Gear
I'm replacing gear and roll pin on SBC, I was able to pull gear off by hand. Snug but not pressed on is this a pressed on fit to not completely rely on pin for strength ? New gear is on way so can't check new gear fit
thank you
racer913 is offline   Reply With Quote
Old 08-18-2020, 04:27 PM   #2
Hacksaw
Liked 310 Times in 174 Posts
Default Re: MSD Pro billet distributor replacement for SBC Gear
Never seen a SBC dist. gear that was pressed on. Snug fit and the roll pin secures it.
Old 08-18-2020, 04:30 PM   #3
FED 387
Liked 333 Times in 180 Posts
X2--but they should not be real sloppy either --kind of a gentle tap with a SMALL rubber mallet to help it slide on--dont BEAT IT ON--just a little harder than hitting it with your fist--some go on real easy and some are "snug" --if need be try a scotchbrite pad to "polish" the shaft --dont go ballistic here
Old 08-18-2020, 08:10 PM   #4
prostockpete1
Liked 90 Times in 52 Posts
i.ve seen some manufactures offer .492 " & .500 " id sizes gears for chevs .. check what you have
prostockpete1 is offline   Reply With Quote
Old 08-18-2020, 09:08 PM   #5
FED 387
also spend a dime and put in a new roll pin and gasket too-- then check your tooth engagement depth and make sure that the distributor has not bottoming out when you tighten the bolt that is too far down
Old 08-19-2020, 08:31 AM   #6
pmrphil
Liked 347 Times in 151 Posts
Not to mention using the correct type of gear for the cam - plain old cast iron, melonized, bronze, composite all have different cam cores they are compatible with.
Phil Molski
PMR Performance
S/C 1623
Old 08-22-2020, 03:21 AM   #7
richie 2
Liked 205 Times in 93 Posts
is there not a referance dot on the gear? can be installed either way?
Old 08-22-2020, 03:14 PM   #8
doug schriener
Liked 7 Times in 6 Posts
Hi-stock Chev is.491,MSD is .500
doug schriener is offline   Reply With Quote
