Old 08-15-2020, 03:38 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default intake castings
Hypothetical question. I know with sbc intake castings(iron) the castings vary a good bit. So, 2 intakes, same casting number, obvious diff production dates. One has around .070 avg wider ports at gasket surface on all ports. is this much variance normal?
jamie2370 is offline   Reply With Quote
Old 08-16-2020, 01:06 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: intake castings
Let me make a guess... the wider/bigger one has an earlier date code..
Adger Smith (Former SS)
Old 08-16-2020, 03:00 PM   #3
SSDiv6
Talking Re: intake castings
Core shift due to an acid trip???
Old 08-16-2020, 05:26 PM   #4
jamie2370
By the amount of views and lack of response....I have my answer
Old 08-16-2020, 08:21 PM   #5
Adger Smith
OK, here is what my friend JV Brotherton (Owner of Brodix) told me when I was complaining about port size/Vol matching specs.
As the molds are used the ports shrink due to the wear on the mold.
I'm not a mold maker so I took him at his word. He said the early part of the production run will be on size and the tail end will be smaller.
I was hoping someone that knew the mold process at GM would take the bait and tell us. I hope that helps. BTW I always flow the manifolds to be sure.
Old 08-17-2020, 01:14 AM   #6
SSDiv6
He is correct. This happened with the old days casting processes.
Old 08-17-2020, 12:49 PM   #7
SDT1DYI
Liked 456 Times in 148 Posts
Best to test intake manifolds on a dyno. They can be different. In one case 15 "stock' CI manifolds same casting #, were tested on one engine , same day. HP varied 15 .
Steve Teeter STK/SS 620.
SDT1DYI is offline   Reply With Quote
Old 08-17-2020, 03:46 PM   #8
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Wouldn't the ports be bigger if molds wear and get smaller?
Glenn Briglio is online now   Reply With Quote
Old 08-17-2020, 03:55 PM   #9
SSDiv6
No. As the intake runner pattern wears with use, the runners get smaller and more material surrounds the pattern.
Old 08-18-2020, 07:55 AM   #10
Ralph A Powell
Liked 226 Times in 137 Posts
With wear the sand core gets larger therefore a smaller port
