Old 08-10-2020, 01:48 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Re: leaking th400
pan manufacturer says fill to the factory full mark...WTF... the flex seal idea is sounding better adger...
Old 08-10-2020, 02:34 PM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Before you start throwing parts at the transmission you really need to locate the source of the leak. My days as a GM tech when I had a complaint of a transmission leak, I cleaned the entire surface areas with brake clean and then used air to make sure it was completely dry. Next I used spray tracing powder and sprayed the entire area., in a short time you should be able to see the powder turning a pinkish color at the source of the leak. It may be as simple as transmission fluid leaking around the front pump cover bolts that would make it look like a pan rail leak.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-10-2020, 03:11 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
I’d say the manufacturer is wrong. In 40 years as a tech, I’ve never started a trans with the level at the full mark.
Old 08-10-2020, 08:35 PM   #4
richie 2
with the pan off, dipstick in, the full mark is higher than the trans/pan surface. the modulator valve bore is right there too....sure seems to be seeping out there. the valve and o/ring fit feels sloppy. measured it all up and installed theres not much crush on the o/ring, .020" roughly...
Old 08-10-2020, 09:56 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
Definitely run the fluid level at the add mark.
Another area I've had issues with lately is the shift shaft seal .
It appears the newer seals are not as tight on the shaft as ones I had from old kits.
My solution has been to machine a groove in the shift shaft and install an o ring .
Old 08-11-2020, 12:20 PM   #6
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
That's interesting. I was just laying under my car last night after installing the engine and trans (glide) over the weekend, and noticed some fluid on the end of the shift shaft which I've not noticed before.
S/ST 51
S/C 53
Old 08-11-2020, 02:15 PM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just a quick heads up.....
Don't use RTV sealer on gaskets because it acts as a lubricant and allows the gasket to push out. Just completely clean both surfaces and use brake clean to remove any residual oil and use the gasket only...
OR
You can do like GM did, which was do not use a gasket at all. You can use anaerobic sealer or RTV, with the surfaces clean and bone dry put it together. Woks on engines and transmissions, just make sure it is allowed to dry and set up before exposing it to oil. This isn't for a race engine or transmission which is constantly being worked on, but it works great on a stock rebuild for the street.....
Your results may vary....
Bob Mulry 7516 STK
A & M Motorsports
Old 08-11-2020, 03:18 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You really don't want to use any RTV sealants that will come in contact with ATF . Most ATF has an anti-foaming additive and RTV will destroy that additive . Most manufacturers that seal structures ( like case halves) will use a Poly-Acrylic sealer. PA has no effect on ATF.
