Old 08-06-2020, 10:47 AM   #1
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: Recommendation for AFCO 3840f/BNC front shocks
Watched your video. It’s not the front. The truck spun the tires before the fronts touched. Work on getting the truck to hook and stay hooked. Check your back shocks. Do they have enough extension. I would loosen the front shocks on extension and tighten them on compression. Remove any travel limiters if you have any. What kind of tire and how much air pressure?
Hi Mike,
The driveshaft graph does show a little hump at about .5. The rear shocks are custom valved by Envy Suspension. They have 5.5" travel and set with 2 inches showing. I tightened up the compression on the front to Zero this past weekend....happened to pit next to Gary Stinnett at our bracket race last weekend, and he said the truck just looked stiff. In addition, we just moved the instant center to 46" out, 7.5" up and bottom bar down 1.9 degrees, and will TNT this weekend. Tires are MT 3074S with 9.5 psi and about 40 runs on them now. Gary said he thinks the tire is bouncing up and maybe even go up to 10.5 psi.
Thanks,
Clark
Old 08-06-2020, 12:27 PM   #2
James Perrone
Liked 1,829 Times in 427 Posts
Santhuff
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 08-06-2020, 12:56 PM   #3
Hacksaw
Liked 311 Times in 175 Posts
Don't buy anything, yet. With 1.40 60's I can't see you having HP/spin issues. Think you need to spend more time on the back end. Also don't care for the stiff sidewall slick.
