Liked 239 Times in 90 Posts
I swapped from 993 to 882 heads on my nova. Same rockers and pushrods but now rockers are trying to push off the side of valve. Am I correct in saying that guideplates are legal now?
Liked 586 Times in 162 Posts
Guide plates are legal double check pushrod length too though.
Someone else might have other items to check |
Liked 14 Times in 8 Posts
Installed valve height, spring o.d.,, length and press.
Liked 307 Times in 103 Posts
trying to push off side of valve as in left/right(front/rear of car) ??? if so use adjustable guide plates.... they adjust side to side separately, so you can center rockers, side to side on valves... drill pushrod slots to1/2' in the heads or guide plates won't be doing anything to locate rockers.....
if talking off tip of valve as toward intake or exhaust side of heads... then you are talking geometry... pushrods too short/long... wrong pivot point rocker(AKA wrong rockers... Last edited by Mike Taylor 3601; 08-04-2020 at 12:43 AM. Reason: addition |
#5 | |
Liked 799 Times in 236 Posts
I assume you're using a spring like the PAC 1409X? If so, a 5/16", .105 wall push rod will work but a 3/8" .080 wall is better. You'll gain you a little lift (due to less deflection) so make sure and check this if the cam is close with smaller push rods. https://www.competitionproducts.com/...products/2262/
"That'll never work....." |
#6 | |
pushrod holes were drilled and no guide plates... that will do it every time LOL
maybe had rail rockers before? they have groove or roller version has washer like pieces on each side of roller to keep rocker lined up on valve tip... |
Thats what I figured. Thanks Mike. They were a spare set I got with the car and did not have studs in them. Guessing they robbed the studs and plates lol. At least they left the Ferrea valves lol
