#11 |
Liked 880 Times in 311 Posts
Does any one want to tell what the dual rating on AV gas is about? like 115/145 ??
Choices: A. Heat value B. Resistance to engine icing C. Octane D. Volatility rating
Adger Smith (Former SS) |
#12 |
Liked 230 Times in 94 Posts
Wow, weren't you lucky to get to use that stuff.I got to use 100LL for years,in Florida but if you try to by it where i now am, you get treated like a crimminal.Now, I love all of the stuff I buy from VP. but I will notice little bits of trash in the screen of the funnels I use, the funnels are the ones alcohol guys use with a very fine mesh screen in it. One is for my car, and the other for my small engines. This is with 110 or SEF. Just wonderin'. John Kissel K242
#13 | |
Liked 706 Times in 283 Posts
I thought the high number was heat value, but I cheated and went to google |
#14 |
Liked 37 Times in 33 Posts
When I use to do a lot of street racing back in the day I would buy AV gas from the local airport.(Told them I was using it at the dragstrip). They told me it was 105 octane. I would then mix Super 104 +" Real Lead" with it to up the power a little more.
Adding one quart of "Real Lead" additive in 20 gallons of AV gas would take it up another 5-7 numbers. Seriously, 1 gram of metallic lead per gallon of gas equals a level of protection no substitute can match....Not to mention it stops knocks, pings, run-on, overheating and piston damage caused by fuel that's too low in octane. |
#15 |
Liked 320 Times in 102 Posts
115/145 was 115 octane lean & 145 Auto Rich or Military Power...
We also had a a J-34 jet engine under each wing that used 115/145 for fuel and part of our pre-flight was to reach inside the tailpipe to break of the stalactites of lead from the fuel. Flew in P-2V Neptunes .......2 turning & 2 burning
#16 | |
Liked 69 Times in 33 Posts
I didn't, but I'm familiar with them. We have one on display at an aviation museum that I'm involved with, and the Royal Canadian Air Force also flew them for a few years. |
#17 |
We have some winners...Basic.. rich lean octane..
The only thing that hasn't been mentioned is the chemical enhancement that AV gas has to help keep Carb ice from forming. It doesn't cool like racing gas when it evaporates/vaporizes. So it puts some heat in the induction system that race gas doesn't. Personal Experience: My 172 with the 300 Continental "6" engine runs better on a 50/50 mix of 100LL Av Gas and non ethanol 87 octane pump gas. Simply because the engine was designed for 85 octane gas. I have an STC to fly with automotive gas, but the mix is better. BTY: Jeff and Bob I have an old friend that has been working for a company leasing planes to the Govt. for fire suppression. He started off flying a modified Neptune and moved up to a DC-10. Somewhere I have a video of him in the Neptune making a run on a ridge that was on fire... Cool stuff.
Adger Smith (Former SS) Last edited by Adger Smith; 08-02-2020 at 04:37 PM. Reason: Add |
#18 | |
Liked 184 Times in 113 Posts
I know they were put on Connies that made 3350hp... |
#19 | |
They had 3 PRT's Power Recovery Turbines each rated 150HP that fed the power directly back into the crankshaft using a reduction gear setup. They grouped 6 of the 18 cylinders together so the exhaust of 6 cylinders powered each of the 3 PRT's. We even had an R-3350 with a Chevrolet Bow-Tie build plate. Back then my rating was AD(R) 2 with the R standing for Recips. Punched a lot of holes in a lot of clouds.
#20 | |
Got something like 3000 hp. Never went past that stage. Most everything they developed in WW2 We are using today. |
