#21 |
Liked 5 Times in 4 Posts
My cousin has a '71 Chevelle it's a bracket car, weighs 2920 with a 555 CI,runs 550s in the eighth mile with a 12 bolt. He was only getting about a hundred runs out of a ring and pinion but switched to a 488 I believe has a larger pinion? It has a t a girdle on it and good axles and spool but it's nothing special.
#22 | |
Liked 19 Times in 17 Posts
#23 |
Liked 883 Times in 237 Posts
Since I have parts for both 12 bolt and Dana 60 in the shop right now ,I decided it was time to weigh in ,literally by putting everything on the scale.
Both rears measured within an inch of each other ,12 bolt 53" ,Dana 54" both have 1/4" chrome moly tubes and 3.15"bearing ends, both have steel caps. Dana 60 90 pounds , 12 bolt GM 70 pounds Both have Strange light weight steel spools Dana 60 13 pounds 12 bolt GM 8 pounds Both have standard non lightened gears Dana 60 16 1/2 pounds 12 bolt GM 14 pounds Axles and bearings and yokes are within ounces So the total unsprung weight difference is 27 1/2 pounds and rotating weight difference is 7 1/5 pounds. The Dana still is better for frictional loss efficiency than the 12 bolt but that surely is offset by the difference in rotating mass. Bottom line is both have their strengths and weaknesses . Ratio choice is much better for the 12 bolt for sure , and if we are talking a Stocker ,well you know what you have to do .
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 07-30-2020 at 11:18 AM. |
#24 |
Liked 111 Times in 25 Posts
Question, what does a COPO, Cobra Jet and Drag Pack cars have for rear ends and what gear ratio and tire size? Thanks
#25 |
Liked 225 Times in 136 Posts
9 inch Fords in Chevy new Mopar and Fords
#26 |
What gear ratio and tire size on those different manufactures
