Old 04-19-2019, 07:01 PM   #11
Liked 5,147 Times in 1,964 Posts
Default Re: Legal ways to light car.
Wanted to know how to handle bumper braces.
What is considered legal lightening?
Are there any aluminum components that would work?
In answer to your initial question..No, aluminum or drilled out bumper brackets are not legal.
However, if you're a hands on type, with metal working skills and tools, there's lots of places where you can removed a pound or two, and not be noticed.
If you're a checkbook / bubble pack racer, you're just going to have to open the wallet wide and kick it out..It's only money.
Old 04-21-2019, 10:10 PM   #12
Tom Meyer
Liked 354 Times in 120 Posts
Look for after market glass, steering gear, steering shaft. Tom
Tom Meyer 5240 SS Stock ???
Old 07-15-2020, 05:37 AM   #13
TommyPettigrew3076
Liked 26 Times in 11 Posts
I use a single core aluminum radiator. Alum is lighter than brass. Also the single core reduces the amount of water in the system. My system holds just over 2 gallons. Small fuel cell. 3 gallon cell and only haul a couple of gallons of fuel in the car. A gallon of fuel is about 7 lbs. water is about 8 lbs per gallon.
Hey mike you ever had any problem with your lithium battery ? And what brand if you don’t mind me asking
TommyPettigrew3076 is offline   Reply With Quote
Old 07-15-2020, 06:35 AM   #14
richie 2
Liked 205 Times in 93 Posts
and cost please/thankyou
Old 07-15-2020, 08:58 AM   #15
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
No issues with the lithium battery. You do have to take care of it charge wise. It charges quick usually about 20 minutes after the run. I have a Go Lithium brand battery and charger. Check with them as they run specials every so often the battery is about $600 plus the charger. I have been using it for about 5 years. I only run one of them and have not had any issues with power in the late rounds. I carry a pony battery in the trailer to run the water pump and fan to cool the car after the run while the lithium battery is charging.
Mike Pearson 2485 SS
Old 07-15-2020, 10:23 AM   #16
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Seats,front and rear ,wiring harness, sound deadener , factory carpets ,all the unnecessary underdash stuff ,} defroster ducts and dash controls must stay }are the biggest gain for the least expense.
Door guard beams are also good for quite a bit of weight .
Aluminum bolts and screws on non suspension parts can reduce as much as 15 - 20 # on big cars. using the shortest bolts possible elsewhere all adds up.
Getting rid of the factory fuel tank in favor of a 3 gallon cell and pump is a big weight loss, but will take several hundred bucks from the budget. .
On the more pricy side are the lithium batteries ,but the weight savings are huge and when getting to the last 30-40 # is necessary an expense that may need to be taken.
I've had very good results using batteries from Antigravity Battery .
You mentioned adjustable seats , unless drastically different size drivers are going to be running the car, a waste of both money and weight .
Some modern steering wheels are are very heavy to dampen vibration, and to frevent breakage during airbag deployment .
Ive found light wheels that weigh as little as 1 3/4 pounds [Stock car stuff]
Old 07-15-2020, 11:38 AM   #17
bykr
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 07-15-2020, 03:50 PM   #18
james schaechter
If you thought sound deadner was a necessary part of a stocker you need to re think your goals. Seriously, scrape that off and read the thread. Some great commons sense ideas here
OK... FWIW
I lost 20 pound of wrinkle filling fat last year..!
Think that helps.
The body right now is a Shell on a rebuilt Chassis.
Did have the floor sprayed with a sound deadener.
Have the Stock Carpet and Headliner.
What are the Best Adjustable Seats?
It has the Stock Drums on all fours.
What Disk Brakes are recommended for this car?
What Booster is used for Power Brakes?
Lightweight Lithium Batteries, good idea.
Is it useful to have two batteries? (one in Trunk)
What about wheels?
James Schaechter 3163 STK
Old 07-15-2020, 04:03 PM   #19
Tom Goldman
Originally Posted by bykr View Post
Actually ,a lot of the glass for older cars is substantially thinner {i.e. more cheaply made] and not as expensive as O.E glass.
I've seen some windshields that came from Mexico , China and South Africa that were 12 -15 pounds lighter than original and were not overpriced .
Optical quality ,sometimes I've had to say no ,get me another one .
I put one in an AMX that was actually 18# lighter than an O.E.
