Old 06-23-2020, 01:29 AM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Racepak O2 sensor
13.8 is rich by around one point. Perfecto is 14.7.
Dale Shearon
68 Mustang 6394
Old 06-23-2020, 07:17 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
14.7:1 is only perfect for a street car on pump gas. It is a compromise that a few different factors meet @ to be stoichometric. (for emissions to make the catalytic converter work its best) USUALLY, when you mash the gas you want the AFR to drop to around 12:1 - 13:1. Different manufacturers and different cyl head designs, compression ratio's and probably several other factors determine where an engine makes its best power @.
18:1 works for mileage but sucks for power, if you can keep the fire lit.
https://x-engineer.org/wp-content/up...io-300x296.jpg
Dave Noll, EF/S ,?/SA 6526
Old 06-24-2020, 10:38 AM   #3
FireSale
FireSale's Avatar
Thanks. That got me to read more.
https://x-engineer.org/automotive-en...e-performance/
Dale Shearon
68 Mustang 6394
Old 06-24-2020, 06:35 PM   #4
Dave Noll
Dave Noll's Avatar
If you want to read more, try some of David Vizard's stuff.
