#40 |
Liked 1,443 Times in 302 Posts
You might try messaging him in Facebook. I think if you have the shift rails and the tail housing loose and the Input hanging forward out of the front of the case you can push it in. Depending on how worn your bushing is, it may be a but tight so do it at home if you can in case you need to polish it a bit.
James Schaechter 3163 STK |
