Liked 13 Times in 7 Posts
Thank you for the quick responses.
N/A |
Liked 314 Times in 177 Posts
The way I read the rule book it says, " any model transmission, same make as car, with a maximum of three forward speeds". To me this means you could have or a 283" Chevy in a 98 Camaro SS /GT with a 200 metric or turbo or .....
Liked 237 Times in 126 Posts
I'm not sure about this. In GT weight is linked to the transmission you want to run but I'm not sure a factory match is required in the finished car.
The rules state weight is determined using the heaviest weight gas engine with appropriate transmission available. So to find the shipping weight of a car for stick or auto application, find that car's heaviest weight in either stick or auto for the weight factor. There is no transmission section in the GT section, just shield requirements. That means you look back to SS which reads any model trans same make as body with forward gear limits. Nowhere does it state stick must be stick or auto must be auto for any flavor of SS. Adapter plates are allowed. You can bolt up a trans that's not designed for your bellhousing. If you are allowed to drop a motor from a '60s station wagon into the "trunk" of a Cobalt, why can't you bolt an auto to a stick only engine like a '70 BOSS 302 Mustang? In one, you rebuild the entire car. In the second you change the trans/bellhousing.
#5 | |
Liked 1,032 Times in 283 Posts
Except when you try to put that Boss 302 in a different body to run GT, it only gives you stick class Stick only engine combos are only allowed to run in a stick class. Same goes for the 85 mustang carb 302. Duane
Duane Hoven 1342 SS/GT |
I have heard this numerous times on Class Racer but I can't find anything in the rules to support it. I simply can't find any rule restricting stick only showroom motors from being used with auto trans cars in GT.
#7 | |
Liked 534 Times in 143 Posts
"Reserved for foreign and domestic factory-produced automobiles and sports cars. Classified per NHRA performance rating as listed in the Official NHRA Stock Car Classification Guide. Only those cars listed in the guide are eligible." The reference at the beginning of the Super Stock GT section: "Reserved for foreign and domestic factory-production two-door coupes, two-door sedans, sports cars, convertibles, or station wagons with any production V-8 engine of the same make. Year of engine optional. Only those engines and/or bodies listed in the Official NHRA Stock Car Classification Guide are eligible for competition." You can view the class guide on NHRAracer.com for the 1970 Ford as an example. The GT section references both manual and automatic transmissions. Look under the 302 column and you will see only HP factors for the manual referenced and none for the automatic for OEM heads or replacement heads. Which means the manual transmission is the only one in the guide and eligible for competition. There is no factor if you wanted to run an automatic so it wouldn't be eligible. |
