Liked 239 Times in 114 Posts
You can probably do that with an rpm controlled switch like MSD sells , or possibly ACD has something that works . This is going to be a big deal since there isn't too many options anymore to get a controller for an e-trans .
Liked 10,708 Times in 2,229 Posts
Joel's on Joy may be able to help.
Liked 229 Times in 68 Posts
It is not an e trans issue. I'm just looking for some thing to make the 1-2 shift by rpm, then manually shift the 2-3 shift. I know there are RPM activated switches, but I'm looking for the actually mechanism that will perform the shift on the shifter itself. I thought I had heard of people using something years ago that did this function, shift 1-2 electronically, but allowed the 2-3 shift to be performed manually. Again it's a reverse pattern turbo action cheetah shifter and turbo 400 transmission.
ACD has a kit that works with a Turbo Action shifter . That's what I use on all my cars .
Liked 72 Times in 36 Posts
Acd 610-987-8999
Liked 564 Times in 66 Posts
What class of car? Stock? Superstock? Bracket?
If Stock, year and model? What kind of trans did the car come with? Did the original trans shift electrically? All of this will lead you to what is legal for use if Stock class racing. If Bracket or Superstock racing than just about anything goes. |
Liked 704 Times in 281 Posts
Any dual rpm box. Set 1-2 shift to desired rpm. Set 2-3 shift to 9999 rpm and shift manually. Will work unless you need more rpm then 9999
