Old 06-01-2020, 08:26 PM   #1
B Parker
Liked 2,336 Times in 464 Posts
Default Re: Metric 200 - What do I need to make one last
Real simple Sepanek Racing Transmissions. I have 75 runs on his metric in a Big Block Chevy stocker. It's a 1970 402/375 hp making 635 hp. It's the fastest trany I've had in my car and it has lasted. BP
Old 06-02-2020, 05:21 AM   #2
Lee Valentine
Liked 319 Times in 68 Posts
Sepanek all the way,best and fastest out there
Lee Valentine 1661 STK
Old 06-02-2020, 07:32 AM   #3
KennyAnderson
Liked 357 Times in 119 Posts
Thanks guys and keep em coming! I've been told the Metric 200 is about a tenth faster than a TH350. Hoping this is true??? I would hate to leave that on the table but I'm wrestling with the durability of the 350.
KennyAnderson is offline   Reply With Quote
Old 06-02-2020, 08:20 AM   #4
GUMP
Liked 2,354 Times in 554 Posts
A good one will be fine behind an LT1. It will also be a little faster.
GUMP is online now   Reply With Quote
Old 06-02-2020, 08:35 AM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Billy Lynn does also a great Metric 200. If you've got a TH350/400 convertor, you can have a input for those installed along with the appropriate pump mods. The governor driven auto 1-2 makes them very consistent. The JW bell housings are a worthwhile addition or you can fabricate a brace for the stock case. Also, the Lokar flexible dipstick makes life a lot easier. The marks on the Lokar unit aren't correct so you need to remark it relative to the oil pan flange on the case. Retapping the oil pan holes to 1/4X20 from the metric size is another thing to do to simplify things. If you elect to have a roller rear bearing installed in place of the bronze one, the drive shaft yoke will likely need to be turned down about .020 for proper fit.
For what it's worth. -Al
Billy Lynn (501) 278-0651
"That'll never work....."
Old 06-02-2020, 09:19 AM   #6
nhramnl
Liked 358 Times in 83 Posts
I recently had the rear end of my car apart to change the ring and pinion, and when I was re-installing the driveshaft, I noticed that the output shaft of the McClay THM200 in the car seemed to be free to move around an awful lot. I immediately checked my spare McClay THM200, and the output shaft was exactly the same. With the driveshaft installed, the movement was all but gone. Never noticed that degree of movement with Powerglides or THM350s. Does the driveshaft slip yoke stabilize the output shaft that much, in a THM200?
Old 06-02-2020, 09:36 AM   #7
MR DERBY CITY
Liked 7,937 Times in 1,518 Posts
Yes, my first experience with the output shaft alarmed me too......
Old 06-02-2020, 06:23 PM   #8
Liked 5,121 Times in 1,952 Posts
Mike, Yes, with no removable tailhousing , there's no support bushing in the rear, besides the very end one . Cost-cutting, no doubt.
Old 06-02-2020, 08:39 PM   #9
SDT1DYI
Liked 455 Times in 147 Posts
X 2. Scott McClay. Worth every penny and very dependable.
Steve Teeter STK 620.
SDT1DYI is offline   Reply With Quote
Old 06-04-2020, 10:17 AM   #10
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
X3. Scott McClay.!
I use one in my AA/SA ZL1 427
it 60'S 1.28 at 3540 lbs!
Scott is a great guy to deal with and knows how to build a 200 metric to last!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
