Babbitt is the only way to go.
Roller bearings, when turning the camshaft on the engine stand, the camshaft feels drag free and it turns easily. However, during engine operation and load, there is more drag while turning. When using high spring pressures, the loading may cause the needle bearings to fail. |
Liked 54 Times in 24 Posts
The biggest advantage of roller bearings are that they do not need pressurized oiling. So in most V8's you are blocking off 5 oil leaks inside an engine.
Todd Gross 3323 FS/E,F |
Liked 373 Times in 129 Posts
Liked 71 Times in 38 Posts
#5 | |
If you have the right cam journal an lifter bore clearance, you will not have to worry. Yes, they are known to create harmonics issues and it shows in Spintron testing. Last edited by SSDiv6; 05-16-2020 at 05:08 PM. |
Liked 584 Times in 94 Posts
Not Legal in Stock ,,, correct ?
Liked 2,343 Times in 465 Posts
Liked 269 Times in 99 Posts
What you may consider is isolating the camshaft by forming a closed tunnel with oil return run directly down to the pan. Cam, lifters and bearings see plenty of oil maybe too much but would not fall into windage with an internal or external oil return line or limit the fall to the rear only for not 100% effect.
When looking at this a few years ago it's difficult with SBC without a lot of work I spent hours cutting and filing PVC tube to fit planning to pin and epoxy but issues with connecting rod clearance made it too much work at that time and became evident sheet metal would have been a better choice. When searching cases where I could see this actually done this was with a Ford with dry sump much easier to control putting oil in the front and return in the back the tunnel would be filled or nearly. Great idea to apply to a stocker there would be HP there but the labor cost would be more than most would pay but a crafty guy doing it for himself............
