Liked 886 Times in 238 Posts
I would definitely suspect a shorted alternator.
Although some race alternator suppliers recommend against them ,I always use a fusible link at the alternator connection.
Liked 11 Times in 8 Posts
Batteries can do some weird things, I have seen bad cells, plate problems, and I seen one reverse polarity, where the positive terminal became negative and the negative was positive.
Liked 71 Times in 38 Posts
I’ve seen alternators short and drain a battery, plugging in a new starter probably wouldn’t fix that.Short to ground in the starter field windings/armature would make sense.I don’t think a shorted solenoid would cause what you describe.I have seen shorted or worn solenoids engage the starter until the battery runs out of current though.What orientation is the battery mounted in? Like was said , I’d try slowly recharging the battery. It might come back if nothing melted internally.
Liked 115 Times in 35 Posts
Alan, I work on electric forklifts and all kinds of dc battery powered industrial equipment. From your description the problem was what you found, the solenoid or armature in the starter. Usually the contacts weld and will not turn off. Direct short to ground not very common.
Did the cables start to overheat? Seems like it took your battery down real quick. The short must have created a open circuit in your battery, inner cell connector burnt open. If the battery reads 0 volts and will not charge it has a open circuit internally. Probably a better situation if that is what happened, acted like a fuse rather than something else like the cables melting and catching fire until the battery current flow dropped. If the problem originated at the battery should not have damaged the starter. Path of least resistance would have been in the battery itself. |
Liked 799 Times in 236 Posts
Battery is mounted in the normal, transverse location in the factory location (Chevy Nova). The plates in the battery are oriented front-to-rear in the battery.
No over heated cables or burnt connectors when it happened. -Al
"That'll never work....." Last edited by Alan Nyhus; 05-10-2020 at 12:54 PM. |
Tom, I hadn't considered the alternator. It's a late model G.M. 76 amp. converted to single wire with a toggle switch in line to activate it. -Al
"That'll never work....." |
Liked 591 Times in 163 Posts
You can bench test them both now that they are out of the car qnd see which causes the problem. Use jumper cables if it's easier. If the battery holds a charge with nothing hooked up try adding the starter back into the circuit. If it arcs like last time it's the starter.
I am thinking = Probably something downstream of battery.
It will be not hard to troubleshoot the systems and the battery. Let us know what you find. Be well!
Liked 54 Times in 18 Posts
Be very careful with arcs around dead batteries, think hydrogen bombs. They will blow up in your face !
Cautiously checked the battery today and it's toast. No continuity between the negative and positive terminal and it won't accept a charge. -Al
