Old 04-28-2020, 08:09 AM   #1
mcashman
Liked 6 Times in 3 Posts
Default Valve recommendations for Chevy
1969 Chevy 350 300hp with double hump heads 1.94 1.50 valves. What valve is recommended for a stocker?
mcashman is offline   Reply With Quote
Old 04-28-2020, 12:19 PM   #2
GTX JOHN
Default Re: Valve recommendations for Chevy
I am a Mopar guy but......
I thought the 1.94 Heads had the same size 1.60 Exhaust
that my beloved Mopars did.
Yes I know they are not the same valve but similar size.
I prefer a fairly flat (Not tulip) valves.
John Irving
741 Stock
741 Super Stock
Old 04-28-2020, 04:24 PM   #3
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Ferrea
Old 04-28-2020, 05:21 PM   #4
MR DERBY CITY
Liked 8,028 Times in 1,527 Posts
I always had the best results with 8 exhaust and 8 intake valves...Results may vary....
Old 04-28-2020, 05:58 PM   #5
Dissident
Liked 73 Times in 36 Posts
FWIW - Manley has some nicely shaped 1.94" stuff. Nice flat backside. Most manufacturers have 12deg to 15deg backsides. Look for ones that are 10deg if you can.
Now on that comment, opinions may vary, but facts won't.
Regards,
HB2
IG
Dissident is offline   Reply With Quote
Old 04-28-2020, 08:10 PM   #6
mcashman
So non tulip would slightly help fill compression if I have the cc’s in the chamber?
Old 04-29-2020, 08:24 PM   #7
HP HUNTER
Liked 373 Times in 129 Posts
Typically you would start with a bigger valve and shape it down to 1.945. On the exhaust, a tulliped valve is some time used on a 23 degree head. All these modifications are based on flow testing as you go, because on a stocker IT ALWAYS comes down to flow through the intake tract. We use Ferrea valves usually.
Old 04-30-2020, 08:20 AM   #8
HP HUNTER
Maybe the OP should do what you do........call Jim Lewis and wait in the front window for the UPS truck to show up
Old 04-30-2020, 10:18 AM   #9
MR DERBY CITY
Talking Re: Valve recommendations for Chevy
Maybe he should or maybe he shouldn’t. ? One thing is for sure , if he calls Jim Lewis, and waits in the front window for the brown truck to arrive .... He will be a HAPPY CAMPER when he opens that box.....
Old 04-30-2020, 10:33 AM   #10
SDT1DYI
Liked 456 Times in 148 Posts
Valve shape does effect flow rates especially at low lift numbers along with critical seat angles in the head. To make the right decisions, you must have a flow bench and spend the time necessary on it. Other wise you are just guessing. If you want to compete in Stock Eliminator , you better have a very good set of heads that flow well from the .250-390 lift numbers for your 300hp SBC. 291, 041 etc heads.
Buying Dart or similar aftermarket NHRA approved head will get you out or the box better flow numbers.
But you then need to spend the time and money to get the intake runner volumes down to the NHRA CC specification.
Steve Teeter STK 620
SDT1DYI is offline   Reply With Quote
