Old 04-13-2020, 09:55 PM   #21
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: BB Chev HP
Originally Posted by dano View Post
any suggestions on baseline hp needed in a or b/sa?
132 mph @ 3400=602 hp
133 mph @ 3400=616 hp
134 mph @ 3400=630 hp
132 mph @ 3600=638 hp
133 mph @ 3600=652 hp
134 mph @ 3600=682 hp
Old 04-13-2020, 09:59 PM   #22
GTX JOHN
Liked 2,487 Times in 698 Posts
There is only one Steve Wann.
I remember him wandering
about the pits when he probably was
around 13 telling everyone how he was
kick our butts.
AND sure enough for the last 30 +years.....He certainly has
done that!!
John Irving
741 Stock
741 Super Stock
Old 04-13-2020, 10:00 PM   #23
B Parker
Liked 2,336 Times in 464 Posts
You will need to add 200 lbs to that number. sorry didn't catch your second set of numbers
BP
Old 04-13-2020, 10:08 PM   #24
HP HUNTER
Would I be off base if I believe the best 1969 396/375 Camaros that run aluminum heads and are able to run better than -1.20 (and they can) are making north of 700 HP?
Do the math.
No, I know a certain A/S that ran 136 @ Pomona (1000) feet, it didn't make close to 700 HP. What helps a 375/396 is how it carries the power past peak, average HP.
Old 04-14-2020, 06:39 AM   #25
Frank Castros
HP factor; 405 with aluminum heads
8.5 lbs in B/SA = 3,442.5 + 170 = 3,612.50
11.25 index - 1.4 = 9.85
The Elapsed Time (ET) Method
This method uses the vehicle weight and the elapsed time (ET) to finish a quarter mile (402.3 meters) on the formula of Horsepower = Weight (ET/5.825)3.
747 horsepower.
Old 04-14-2020, 08:09 AM   #26
HP HUNTER
747 horsepower.
9.29 @ 142.24 @ 3600 how much power using your formula?
Old 04-14-2020, 09:22 AM   #27
Frank Castros
Approximately 850.
Old 04-14-2020, 09:31 AM   #28
HP HUNTER
Approximately 850.
Could you look into the possibility of HP determined by MPH over 1320, this seems to align with my dyno testing and others over the years. A perfect example of this would be over on the Number1GMfan thread.
Old 04-14-2020, 09:48 AM   #29
Mike Mans
Liked 299 Times in 48 Posts
Originally Posted by B Parker View Post
Mike if you have only 587 you would be in trouble running most of the fast A an B cars. Not that I would know but I would guess your second number of 645 would be in the ball park. Barry
I completely agree with you there. I figured the 587 would put you around an -.80 under car, give or take a little. If a guy wants to be competitive in a heads up race against the top dogs - you'll need that 645 range. Just my perspective.
Mike Mans is offline   Reply With Quote
Old 04-14-2020, 10:23 AM   #30
Frank Castros
None of those "top dogs" will run it 1320, to protect the number.
Maybe Scott Gove might.
