Liked 239 Times in 90 Posts
Fast xfi, analog 7al2, fast dual sync dist. My autometer tach is roughly 500rpm less than what fast data shows. Fast at idle shows 1100 while tach is around 600. Is this normal or if not, what is the fix. I honestly thought I had a low reading tach before I put on efi, just now I have another reference that should be super accurate since its dual sync
Liked 2,361 Times in 558 Posts
Where are you picking up the tach signal?
at the 7al2 box, tach terminal
Is there an unused tach wire on the FAST harness? If there is, it would be worth trying before changing the tachometer.
Liked 269 Times in 99 Posts
Have you tried the tack output in the XFI harness if I recall is the white points wire
I have not had a tach in my car for a while now. I log & play back every pass. If I had a stick car, I would need one, wouldn’t I? Or a shift light. LOL
Ed Wright 4156 SS/JA |
That's what is firing the msd box. Seems the more people I talk to I am thinking it's a tach issue. Nobody seems to have this problem. And a Tach is a necessity in Stock. Foot brake, and reverse pattern ATI 350 means it's all on me lol
Liked 328 Times in 80 Posts
I have used a digital hand held tach that uses a small piece of reflective tape on the damper to verify which is correct.
Ernie Neal SS 354 |
