Old 04-02-2020, 03:07 PM   #1
Dave Gantz
Liked 251 Times in 125 Posts
Default Self Adj To Manual Adj Drums
I have a 9" Ford. Does anyone still make a kit to convert from self adjusting to manual adjusting?
I've been searching around without any luck. I guess I'm showing my age, but I stopped having birthdays years ago.
Old 04-02-2020, 03:10 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Self Adj To Manual Adj Drums
Couldn't you just remove the lever and the spring ?
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 04-02-2020, 03:44 PM   #3
Dave Gantz
Not quite, the manual star has a spring that keeps it from spinning. The auto stuff could still tighten.
Old 04-02-2020, 03:58 PM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Put a dab of silicone on the adjuster to keep it from tightening up.
Lee Valentine 1661 STK
Old 04-02-2020, 04:04 PM   #5
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I just went to the hardware store and got some locknuts. I adjusted the brakes to about .010 clearance with 0 - 12" dial calipers.
Dave Noll, EF/S ,?/SA 6526
Old 04-02-2020, 08:08 PM   #6
Dave Gantz
Thanks for all the replies. I've been searching and I think I've found what I need.
Early 60's Fords have the 9" rear and manual adjusters. I found only them ("manual drum brake adjusting screw") at Rockauto. No springs.
Found a brake parts set that looks like it has the right return spring. (early 60's Ford with 10" brakes) They're available at a lot of places. One of the manual adjuster return springs is longer, because the auto adjusting stuff is out of there.
The other thing I needed is a spring to hold the adjuster in, and hold the bottom of the shoes together, while it captures the star wheel so that it doesn't spin. I found what look to be the right one at Macs Auto Parts. ("brake adjusting spring", a different one is listed as "auto adjusting spring")
Esentially, I found the parts separately. The used to come in a set. It all looks good, but I won't know for sure until I try them. It's all cheap enough.
Hard to describe, but I'll post a couple pictures if and when I get it together.
Old 04-02-2020, 08:30 PM   #7
Keith 944
Keith 944's Avatar
Do you plan on getting two sets and using just the longer shoes? I used to do that on my footbrake cars
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-02-2020, 08:53 PM   #8
Dave Gantz
No, I'm just replacing the needed hardware.
Old 04-03-2020, 01:08 AM   #9
Chevy55
Banned
Liked 179 Times in 89 Posts
Try a heavy repair truck shop, they usually do brakes on everything and might still have the adjusters and springs that you need.
The manual adjuster has a course gear wheel.
https://www.summitracing.com/parts/s...two-ten-series
Chevy55 is offline   Reply With Quote
Old 04-03-2020, 09:12 AM   #10
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Please tell me this is an April fools joke...LOL
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
