Old 03-29-2020, 08:19 PM   #1
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Cylinder head heat crossover?
Thank you. But on Olds they have a steel valley pan/ intake gasket all in one
I might trim the steel valley pan to allow for these gaskets to work. That might be the ticket.
Also I was going to use stainless steel for blocking.
Jeff Stout is online now   Reply With Quote
Old 03-29-2020, 09:59 PM   #2
A little lead is good for it. LOL
I can't remember if there are 1 or 2 exh. passages up to the intake side, but you want them completely filled and separated so the headers scavenge correctly. I've done many, many sets that are out there, using molten aluminum.
Also you want to mill the exh . side until the center ports are completely divided. Either that, or build up a dam on you header flanges.
Old 03-29-2020, 10:00 PM   #3
FED 387
Liked 335 Times in 182 Posts
4 suggestions
1-Edelbrock #2733 plug ---about $12
2-Mondello #HR-351 insert---about $25
3- fill the cavity with liquid aluminum or maybe try JB weld
4- fabricate an aluminum plate to fit between the gasket and the cylinder head might have to resurface the manifold to compensate for the space
FED 387
Old 03-29-2020, 10:10 PM   #4
Jeff Stout
Originally Posted by FED 387 View Post
4 suggestions
FED 387
Thank you. I think the stainless insert will be the way..
Old 03-29-2020, 10:45 PM   #5
I don't know that you can't block the intake, if they let you fill the head all the way down to the port.
You could take a chunk of 1/4 " aluminum or steel and make a plug with tapered sides, and bang it in there.
No bubble packs here, unless we have to.
Old 03-29-2020, 11:13 PM   #6
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
2020 Rule book: Stock Cars
Cylinder Heads
“Heat riser passage may be blocked from intake manifold side of cylinder head. Blocking passage down in the valve pocket prohibited.”
My interpretation: don’t block anywhere down into the head, but that’s just me. I would hate to get busted for plugging the head when a thin piece of stainless will be sufficient.
Kelly
Shadylane is offline   Reply With Quote
Old 03-30-2020, 12:23 AM   #7
Cylinder Heads
Kelly
Kelly, As long as the plug is recessed a tad and not reshaping the port, it's fine. We've been doing them that way for year....Hettler /Kadar/ Watters , and others.
Old 03-30-2020, 12:39 AM   #8
older racer
Liked 68 Times in 26 Posts
hi, I found .015 stainless sheet works excellent. used same ones for last 10 years, has never burned out or blew a hole through it. mine are 2" by 2 1/2 "just food for thought.
older racer is offline   Reply With Quote
Old 04-02-2020, 11:35 PM   #9
HP HUNTER
Liked 373 Times in 129 Posts
"No bubble packs here"
I could of sworn that was you standing in the window waiting for the UPS truck intently LOL
Old 04-03-2020, 12:41 PM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Cylinder head heat crossover?
On applications that can use sheetmetal to block the crossover, I've had good luck with aluminum (thicker than cans) if glued & coated on the inside with a good hi-temp silicone to help insulate it.
LOCOMOTION Racing
