Old 03-28-2020, 03:37 PM   #1
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Factory efi
Originally Posted by House of Darts View Post
Might take a crack at racing a Ford 4.6 in stock . Do I keep the factory EFI set up or is there an aftermarket unit? Change out the computer from the factory unit with what? I've seen the set ups with the FS cars and I don't think I can use this stuff.
You can use the stock computer with a TwEECer.
www.tweecer.com
Dave Noll, EF/S ,?/SA 6526
Old 03-28-2020, 05:38 PM   #2
GUMP
Liked 2,354 Times in 554 Posts
Save yourself a ton of grief, switch to an aftermarket system. It will pay dividends in the long run.
Old 03-29-2020, 10:58 AM   #3
Ed Wright
Ed Wright's Avatar
Originally Posted by gump View Post
save yourself a ton of grief, switch to an aftermarket system. It will pay dividends in the long run.
fast xfi!
Ed Wright 4156 SS/JA
Old 03-29-2020, 11:43 AM   #4
GUMP
Originally Posted by ed wright View Post
fast xfi!
Holley EFI!!
Old 03-29-2020, 03:08 PM   #5
Ed Wright
Ed Wright's Avatar
Originally Posted by GUMP View Post
Holley EFI!!
I have tuned several with both FAST XFI & Holley. I would certainly disagree. I can & do make the FAST system do things the Holley can not. Besides the Holley ECU failures I have seen.
Old 03-29-2020, 09:20 PM   #6
GUMP
I have five cars running Holley. I have never had one issue.
Old 03-30-2020, 08:24 AM   #7
Rob Wright
Liked 21 Times in 7 Posts
Can you give specific examples, and describe the impact of those things?
Rob Wright is offline   Reply With Quote
Old 03-30-2020, 08:59 AM   #8
Rsmith38
Liked 28 Times in 15 Posts
While I only have 1 jeep running the Fast XFI2, I am quite happy with it. Bought used on EBAY - (replacing the obsolete silver FAST - no longer supported). It is still a work in progress - not a lot of Jeep 4.0 support (on anything!) but no tech problems at all over 2 years.
1051 StK
Rsmith38 is offline   Reply With Quote
Old 03-30-2020, 10:37 AM   #9
Robin Lawrence
Sponsor
Liked 714 Times in 120 Posts
LOL, I am with you on this Rob. I hear this from time to time while at the Track. You would be surprised at how many people haven't scratched the surface with the capabilities of the more recent EFI units available today.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 03-30-2020, 05:25 PM   #10
Ed Wright
Ed Wright's Avatar
One thing is something I was doing with my old Jr Stock ‘56. Running more timing in low & second gear. Something Jere Stahl put me onto over twenty years ago. I now run different timing in each gear. Easy 5 hundredths there. Jere told me he and Bill Jenkins had done that for years. Used to do it with our old dual point distributors & a toggle switch. “Turn on” the second set of points to retard the timing. I had re-drilled the breaker plate in my ‘56 Corvette distributor to move that one set of points to adjust the amount of retard. Spent most of a day on my Sun “distributor machine” working that deal out. Had the toggle switch mounted where my Hurst shifter tripped it going to high gear. I was much younger then, could usually remember to flip the switch back on the return road. LOL My FAST ECU does it all for me now. I do have a toggle switch now that shuts that function off, to help slow the car down when I don’t need it. The FAST XFI ECU can hold 5 “tunes”, I just use two.
