Old 01-07-2020, 10:10 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Re: 1956 Chevrolet Handyman Wagon
Does the 1956 engine have different pistons than the 1955?
The '55 pistons are flat tops with no valve reliefs. For '56 and 57 the 265 pistons had valve reliefs added.
Chad E532 is offline   Reply With Quote
Old 01-09-2020, 11:27 AM   #2
Lyn Smith
Liked 997 Times in 201 Posts
The 55 265s and early built 56 265s had flat top pistons, but GM stopped production of them mid 1956. You could not even order them from a dealer from mid 56 on.The part number was discontinued. If you build a 55 Stocker you must use the flat tops, and you must use a cam with 230 or less duration because of no piston to valve clearance. NHRA let the Jr Stockers use the valve relief pistons back in the 60s,and early 70s,but not now.
Old 01-09-2020, 04:34 PM   #3
Chad E532
Chad E532's Avatar
Continuing with the tear down.
Mid 70's suspension technology at its finest.
Name:	20200108_195151 resize.jpg
Old 01-09-2020, 06:26 PM   #4
Liked 5,139 Times in 1,962 Posts
Jerico !
