Old 01-03-2020, 06:47 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Oil pre-heater
Originally Posted by Ron Gusack View Post
I just got a couple Moroso 23991 400 watt probe type heaters and I've been told they can scorch the oil. I notice that the Stefs is a much lower wattage. Which oil/trans oil heater do you use? Thanks for your advice.
We put heaters in the oil pans and hydraulic tanks of heavy equipment on a regular basis, the general rule was no more than 10 watts per square inch of heating element. High wattage units made for water will cook the oil. More info here, https://www.warrenelectriccorp.com/a...rs/default.asp
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 01-03-2020, 08:56 PM   #2
bykr
Liked 167 Times in 81 Posts
I siliconed the Moroso heater to the bottom of my aluminum pan worked great, but would leave it on for only about 30-45 minutes.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-03-2020, 11:31 PM   #3
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Thanks for that information Jim. If my math is correct, this heater has 63.69 watts per sq. in. I guess I'll send both of them back. The heating probe is 4" long and .5" in diameter with 400 watts.
I tried a stick on pad but when I saw smoke coming out of the diaper after a few minutes, I took it off.
Ron Gusack is offline   Reply With Quote
Old 01-04-2020, 11:18 AM   #4
Eman
Liked 133 Times in 76 Posts
Some have used a plumbers pad, available at Lowes, to protect their diaper. Pad has to be sealed around the edhes to the pan if it peels it will burn itself up.
