Old 01-02-2020, 01:58 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default O2 ?
If a O2 sensor is going bad what will it do? Mine is showing 18 to 21 AFR now and car is fine and runs the same. Last month it was showing 16 to 18 AFR. No header gasket leak that I can hear or see. Plugs read normal and ET is where it should be. The sensor is about 3 years old with C12 and C16 for fuel
Old 01-02-2020, 02:22 PM   #2
GUMP
Liked 2,354 Times in 554 Posts
Default Re: O2 ?
Where is the O2 located in the header? I normally change my O2 about once a year or at the first sign of an issue.
Old 01-02-2020, 02:29 PM   #3
FED 387
Liked 333 Times in 180 Posts
Default Re: O2 ?
Eventually leaded gasoline will wreck an O2 sensor---It also depends on if its a carb or EFI system---EVENTUALLY if you are using LEADED fuel it is going to fail ---how soon depends on the tune up if you are close initially it might last longer --OR -it might fail in just a few dyno pulls or it might last a few hours (50-75)--I don't think there is anyway to clean them either--you can try soaking the sensors(completely covered) in gasoline for about 8-12 hours to loosen up any residue and then GENTLY use a soft brush to clean any residue that the gas left on the sensor , then use soft cotton cloth to wipe the tip---might work might not -I could be wrong on all this tho--FED 387
Old 01-02-2020, 03:02 PM   #4
Jeff Stout
Default Re: O2 ?
Right at the collector, far from the head. Im going to look close at where the 4 tubes slide in collector now that Im thinking about it. One of the tubes is just the right length and only slides in collector a 1/4 inch. Thinking maybe that tube may have slid out just enough.
Old 01-02-2020, 05:03 PM   #5
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: O2 ?
Jeff
If your 02 goes bad and you see little to no changes,you are most likely on open loop and the 02 has no effect, other than taking readings. Your unit is just following the map, period.(By readings I mean your data recorder in your FI unit, or stand alone unit.) You could also have a well tuned map using closed loop, and whoever did it has the allowable corrections so slim that even if the FI units sees a lean condition, its only making minimal allowable changes. Those 02's always fail in a lean condition, so if the parameters are set high (20-100 %) your FI unit will recognize the false lean condition from the failed 02 and dump whatever is available into the motor trying to correct the issue. That's why most tuners set that value pretty low after finishing up a tune. Just in case of a 02 failure. But I'm guessing your in open loop,,,,,
Hope this don't make it worse, ......LOL
Jeff Niceswanger 3740 SS
Old 01-02-2020, 06:55 PM   #6
cmracing
Liked 62 Times in 29 Posts
Default Re: O2 ?
Originally Posted by Jeff Niceswanger View Post
Jeff
This is how I tune engines. Get them right, then lower the correction limits so in case something goofy happens, you don't hurt your engine.
Yes, they tend to start reading lean when they start to fail. The typical low-dollar sensor usually lasts 75-100 passes, a lot depends on your tune and how you run the engine. Lots of cold starts and running rich shortens their lifespan.
Keep a spare on hand. I used to buy the good NTK sensors for my Holley setup, but the Bosch sensor which lasts about 1/2 the amount of time is also 1/2 the cost, so it's a wash........
I really only use the wideband to log things, I usually run stuff in Open Loop unless a big change has been made or a much different altitude track is going to be raced at. Even then, 5% correction is typically enough.
cmracing is offline   Reply With Quote
Old 01-02-2020, 10:21 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: O2 ?
C12 is leaded. Leaded gas coats the sensor, it will read a low voltage which is interpreted as lean. When I use an O2 in mine, I only use C10.
Dave Noll, EF/S ,?/SA 6526
