Liked 216 Times in 77 Posts
Since no one posted it. On a 4 gen F body. If you have a stock length rear end. Using a 10 inch wide wheel you need 7 1/2 inches of back space.
Liked 13 Times in 7 Posts
The trick is to use an 82-92 F-Body “STOCK WIDTH” rearend. It’s a complete bolt-in for a 93-02 F Body. The 82-92 is approximately 4” shorter than a 93-02 rearend. This is what u r seeing in the pics u posted. Now you can use a 15x10 wheel with a more common 5.5 backspace.
N/A |
