Liked 52 Times in 32 Posts
Been "advised" much concerning correct 1st gear needs for my 3500 lb car with 5.14 gears and 30" tire, behind a decent BB chev Stocker and TH 400 trans. Any "rule of thumb" I should be using?
Liked 536 Times in 110 Posts
You didn't say if it's a Stocker, S/S or bracket car but the stock 2.48 is a good starting point. Keep in mind that we're racing at least 1/8 or 1/4 mile and not just to the 60'. A close ratio trans may result in a slower 60' time but due to less RPM drop on gear changes, could result in a quicker E.T. On the other hand a trans with a wide ratio, say a 2.75 for example may provide a quicker 60' but may fall down too much on the gear change. Converter stall also comes into this discussion as well.
Jim Kaekel 3836 STK |
#3 | |
Liked 976 Times in 311 Posts
#4 | |
Liked 30 Times in 17 Posts
What class and combo BBC?
Liked 162 Times in 45 Posts
Turbo 200 with 2.75 low, swap converter for one for a 200. Put the 400 in a pick up truck where it belongs. The fast big blocks are successfully run in 200s.
..Or 33.5' Class A 454 motor home, like the last one I built for anything ;-)
Liked 484 Times in 160 Posts
