Old 11-26-2019, 01:42 PM   #16
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Dedenbear Lightning Plus Delay Box
Originally Posted by SST159 View Post
I have the same set up and I use a separate timer for the shift. I only tried the SLC a few times on Pro Tree and find the car wants to move around (rock) so I only use it in bracket mode for full tree.
What do you do differently when staging without the SLC to make it not rock?
If you're giving it a little RPM for more transmission pump pressure, you can adjust the length of the SLC so that even when it goes limp it will give you just a fuzz more RPM when your foot is to the floor.
S/ST 51
S/C 53
