Old 11-16-2019, 08:33 PM   #51
Race Clean
Liked 129 Times in 53 Posts
Default Re: What Stock rules would you change?
Just for the Record,I think pure Stock sucks!
But I wouldn't mind the rules to stay put from lets say 10-15 years ago just to keep us separated from SS.
Stop global whining
Race Clean is offline   Reply With Quote
Old 11-17-2019, 03:00 AM   #52
Todd Hoven
Guest
Posts: n/a
Drop all indexes 2 10th’s
Old 11-17-2019, 03:02 AM   #53
Todd Hoven
Guest
Posts: n/a
Originally Posted by DYER View Post
roller lifters for all engines no more broke lifters or worn out camshafts less engine blow ups
Stupid, learn how to pick valvetrain components and this doesn’t happen
Old 11-17-2019, 03:08 AM   #54
Todd Hoven
Guest
Posts: n/a
Limit valve spring pressure. Maybe 120lbs seat, 300 lbs @ .500".
Pontiac had dual valve springs from the factory in some combos that had more open pressure then that. Just saying
Old 11-17-2019, 08:54 AM   #55
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
The 300 lbs. @ .500" was a maybe. Some BBC had dual valve springs too. They also had valve springs with 327 lbs @ .500" lift, though the seat pressure was only 106 lbs.
Old 11-17-2019, 01:17 PM   #56
Five
Old 11-18-2019, 02:33 PM   #57
Jim Caughlin
Liked 805 Times in 245 Posts
What rule should be changed for Stock and SS? How about an AHFS system that actually works? Can't believe no one has suggested this yet? I could write a book about how ineffective this system is. If you got some parity in how cars are factored, all of these other suggestions would not be as much of an issue. And yes, my car is as much of an offender as a lot of others.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 11-20-2019, 09:47 AM   #58
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
AHFS to work properly, what a concept. Sure got quiet on this thread after that post.
Ron Ortiz
U/SA
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 11-20-2019, 03:42 PM   #59
novassdude
Liked 136 Times in 49 Posts
Jim Caughlin
SS 6019
How can the system work when the racers are the ones making sure it doesn't. If everyone ran their car all out every pass it would work. They forgot to account for the fact that you would have all the racers trying to protect there combo at almost any cost. How many have been on hear pissed off because some one with their combo made a pass that got them hit. Used to be that drag racing was to see who could go the quickest in a quarter mile. It doesn't help that the NHRA let the new should be in comp cars race in stock with very generous HP factors.
novassdude is offline   Reply With Quote
Old 11-20-2019, 05:37 PM   #60
Jack McCarthy
Liked 477 Times in 117 Posts
Hmmm where have I heard that before ?? 🤔 the Automatic Help For Slugs cannot and will not ever work. Just because we control the data that was easy. That was day one before 1. National Opens don’t count 2. Oh crap 50% of the field is fast we won’t count them 3. Indy well it’s special we can’t count that ... and then >> well GM said they made it so let’s put it in the book at its ORIGINAL HP not gross and oh one more ... if you read the rules and properly sandbag SHAZAAM the HP fairy will reduce your combo (fffords just get the 300 combos at a time) 😡😡😡
Anyway no one listens to me 😢
Captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
