Old 10-16-2019, 08:23 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Converter Slippage at top end
Not sure why you included this info, but if you're going to use a T200 and an 8" converter, there are plenty of people here who can figure what gear you'll need. You won't have to figure a thing.
Only question would be: Will you have enough steam to run a second under, or are you just looking to run the index?
Hopefully Mark will back me up on this , since he has a lot of converter experience . A 10" converter is an odd choice in stock . Example , To make a big converter stall up at 5000 rpm will trade efficiency and make it slip a high percentage through the traps It is much better to have a 8" converter configured to stall at 5000 rpm , and gain back the overall efficiency through the traps . A bonus of the smaller converter is the coupling point of the converter (the point that converter multiplication goes to 1 ) will be at a higher rpm . A big converter will get to 1 to 1 at a lower rpm , so the car will not accelerate as quickly while the converter gets through this in-efficient part of the converter curve .
