Liked 704 Times in 281 Posts
Kelly I have a new Moroso motor in a box I would sell cheap. I live north Phoenix and work central Phoenix.
Liked 125 Times in 59 Posts
You can get a motor that has 4 posts with 2 of them being the same center to center as the Moroso 2 post motor but is a more powerful permanent magnet motor from W. L. Walker 918-583-3109 or wlwalker.com
The part number is 18051. This is the company I work for. We sell stuff to test measure or sample oil but I used this motor on a few friend's water pump and they run much faster also. Depending on the input voltage they will run 2100-2250 rpm. It has the same 5/16" shaft. Just grind down the 2 posts that you don't need. Just an option to consider. Looks like they are about $11 more than the Moroso motor. ![]() Curtis |
Liked 49 Times in 22 Posts
I use a plastic fan from summit, super lite and pull some air through radiator. with my moroso water pump kit
Steven Barnes Stock 704 N/SA |
Liked 171 Times in 51 Posts
I was digging through my stuff this morning and found a new in the box Mr. Gasket water pump drive kit minus the belt. Forgot I bought it at a swap meet many years ago (box is dated1985), I’m a pack rat.
Called Holley/Mr Gasket and was told this motor would operate at 18/20 amps. Double the amperage of the Moroso. Going to try it and see what happens. Appreciate the offer Jeff, going to pass for now until I figure this out. Curtis that’s a robust looking motor, I’ll keep it in mind. Thanks folks for the suggestions. Kelly |
