Liked 302 Times in 73 Posts
We’ve got a pretty good rpm flash during the 2-3 shift. I’ll have to look at the logs, but shift around 5900 on the tach and you can see the tach flash up to about 6400. The 1-2 if there is a flash is much less noticeable on the tach itself.
This has been something we’ve noticed much more since we took the stock 1st gear out and put in a 2.92 ratio. I personally don’t know why that would give us a flash unless when reassembling we got something adjusted incorrectly. Just swapped to a brand new ATI converter and a different cam recently and the car is as fast as it has ever been but the flash seems to be worse.. any suggestions on making it go away and/or if we are losing ET because of it? |
Liked 239 Times in 114 Posts
How often do you adjust the intermediate band ? If it lets go too soon on the 2-3 shift it will flare , and you will see a higher rpm . This is a typical problem with most transmissions that have a timing type shift , there needs to be a little overlap between the band coming off and the high gear clutch coming on , or you get a flare . On a C4 there is a band adjustment .
Liked 26 Times in 13 Posts
There are a few things that affect the flare including which valve body you have (who modified it to full-manual) and which intermediate band servo you are using. There a quite a few different servos that have various apply and release piston areas and accumulator volumes which affect the timing of the band release. The adjustment on the band has a little effect, but it is a fine tuning compared to the hydraulic circuit variables. You should never have a flare on the 1-2. Second gear is the intermediate band applying to stop the direct clutch drum. You might get a slow or sloppy second gear shift, but unless the forward clutch is slipping it shouldn't ever flare.
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 71 Times in 38 Posts
It’s been a long time since I’ve played with C-4 stuff, but I would think the servo or the release circuit would affect this.
#5 | |
What should we be looking at in terms of Servo/Band combo or adjustment to correct said issue. The shift is by no mean sloppy or mushy.. driving through the pits it a nice firm solid shift, but on track it's simply a flare.. no burning of fluid or anything all we're noticing is the rpm flash. not sure we are even losing ET as fast as it happens just seems like something we should be able to eliminate. |
#6 | |
#7 | |
Take a look at a Ford shop manual and torque the adjuster pin to spec , then back off the pin by the recommended setting then tighten the jamb nut . This setting might have to be changed if the band runs against an aluminum drum . Typically if you back off the pin less, the more overlap or tie up will occur (less flare) . This assumes the band and the drum surface is in good condition . Too tight a setting might cause the band to drag and the car slowdown in 1st gear . The high gear circuit needs to be leakfree . With the VB removed you can aircheck these circuits . Check a see what servo you have , If you have a flare problem , an "H" servo might be a good one to use , there are billet versions of that servo available . Also typically a C4 only has a 4 plate high gear clutch , which may not have enough capacity , depending on torque and rpm . A 5 plate clutch pack helps that . A flare on the 2-3 shift could be telling you the high gear clutch is burnt .
It's a little hard to correlate how changing the gear ratios would affect the 2-3 shift action, but perhaps it has to do with the torque and rotational speeds of the drums involved. A 2-3 flare is actually the transmission state going 2-1-3, with the brief first gear state causing the engine RPM flare. 2-3 shift is two actions on the direct drum. In 2nd gear, the drum is held stationary by the band, and to shift to 3rd the band has to release and the direct clutch has to apply which causes that drum to go from stopped to engine RPM in a very short period of time. If the band is released before the clutch is applied, that is actually first gear and the drum starts to rotate in the reverse direction (!!) before the clutch application catches it and gets it rotating in the forward direction. Maybe the higher first gear is applying more torque and a higher reverse RPM to the drum before the direct clutch can catch it. The lower gear ratio would also increase the load on the direct clutch, making it harder to stop the drum ... thus the increased flair. Like SS3011 says, if the direct clutch is slipping, or doesn't have enough capacity to stop that drum which now has more inertia, that would show up as a flair. If that is the case, it's going to burn it up eventually. You may have to play with different band servos to clear it up completely. Maybe call Joel's on Joy and see if they can recommend a servo to go with that 2.92 ratio. That is a LOT steeper ratio than the OEM which is around 2.46 (if I remember right).
Liked 160 Times in 51 Posts
A possible cause of weird flares is end play out of specs affecting sealing ring performance especially considering hard parts replaced that might change stacked clearances. End play spec is .004-.044 but I prefer under .020 or less for race trans and near the low end if it is rollerized. There is not much going on inside one of these...Excessive direct clutch clearance or band adjustment way off will affect the 2-3, but not 1-2.
Those are the most common problems I see if the VB was the same and worked fine before. Probably something simple....I share with my students my 4 rules of auto trans. always check the pump always check end play always check clutch clearances always air check before VB goes on. If it passes these 4 checks the worst you usually have is a VB problem which you can fix in the car..all the rest, its coming back out!
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
