Old 09-06-2019, 12:25 AM   #1
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default 4th Gen F Body V6
Is a 4th gen f body with the 231 V6 a good combo?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 09-16-2019, 03:15 PM   #2
JakeB23
Liked 17 Times in 3 Posts
Default Re: 4th Gen F Body V6
I have also kicked this idea around, since we still have my wife's car from High School, and its in great shape.
The biggest problem I have, is that its a bear to work on, with the engine so far under the cowl. Maybe some racers with this type can shed some light on this.
JakeB23 is offline   Reply With Quote
Old 09-16-2019, 05:22 PM   #3
Mike Gray
Mike Gray's Avatar
Liked 693 Times in 201 Posts
I just put new heads on my sons car without removing the engine and drive train out the bottom.
just pull the radiator, and sway bar and you can stand in the engine compartment In front of the motor. (If your not too large) After you leave off the unnecessary brackets and accessories it should be fairly easy work on. Didn't even remove the hood, you need some shade when working in there.
Old 09-17-2019, 11:40 AM   #4
Liked 5,131 Times in 1,956 Posts
Which one?
Old 09-17-2019, 03:37 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I think the 3.8L Series II engine is a good pick . Doesn't Harry Doolittle run one in his Firebird ?
Old 09-18-2019, 01:04 AM   #6
Darrel Goheen
Which one?
3.8L Series II is what I was looking at. Thanks.
Old 09-18-2019, 05:58 AM   #7
GTOMayhem
Liked 22 Times in 14 Posts
Lee Norton, the Racer Tees guy, ran a Firebird with a 3800 for awhile.
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 09-18-2019, 10:52 AM   #8
Yes , I realize that..1995 and newer..but there's more than one combo in F body cars.
http://www.classracerinfo.com/
Old 09-18-2019, 12:54 PM   #9
jimmyparker
Liked 309 Times in 88 Posts
Ronnie Temento from Louisiana has an N/SA Firebird with this combo and he has been in the 11.80's before. The car is for sale on RJ.
jimmyparker is offline   Reply With Quote
Old 09-19-2019, 12:42 PM   #10
ss3011
ss3011's Avatar
I see what Mark is asking about , one is rated at 185 and the other rated at 200 . It maybe that the FWD version is rated different .
